Engine Seals
odd comment on the pan gasket - maybe there were different styles? I've only replaced one - it had solid metal inserts where each bolt went through, and then the thick soft plastic seal everywhere. Once torqued, there was nothing to loosen because the bolt tension path was all metallic.
