1985.5 944 - how to replace spark plug wires
I thought replacing these would be straightforward but I do not see how you have enough room to thread the wires for cylinders 2,3,4 out as they are under some part of the vacumn system (?) and there is not enough room to pull the end connectors through. Do I need to remove something to get access?
I thought replacing these would be straightforward but I do not see how you have enough room to thread the wires for cylinders 2,3,4 out as they are under some part of the vacumn system (?) and there is not enough room to pull the end connectors through. Do I need to remove something to get access? Thanks
1987 Red 944 N/A *** NOTE- I probably posted from my iPad, please excuse any typos, bad punctuation or odd grammar, if it is unreadable, it probably was posted from my iPhone.
Using the OEM Beru wire set, with a little finnegeling and wire looms, I was able to carefully (so as not to pull apart or kink the wires) route the wires from the ignition cap to each spark plug. Pushing down on the plug and the cap until you hear a click. See my pics for the routing I used. Also a useful tool to pull and maneuver the wires around the intake and regulators is a set of long, 90 degree end, needle nose pliers.
