Speaker Idea
Location: The mistake on the lake other wise known as Erie PA
I been throwing this idea around for some time but I wanted your input on it. On both my rear speakesr there is a double connection so you could put another speaker on the same channel do you think it would be a good idea to build an enclosure and put speakers in the rear sides cutting the carpet and running the wire on the same channels as the two rear speakers ?
No. That would be bad. You'd be running your speakers in parallel, which would give you 2Ohms. Your amp might not be 2Ohm stable. Also there's no point in running two speakers to handle a single channel, just get a single good speaker per channel.
Yes it says 2 speakers on same channel right in the manual but I think I might juss go the right way and buy another amp, but still do the rear enclosures. If any one can give me any ideas on how to do that it will be a great help.
