AEM Booster controller - overboost condition
944 Turbo: Installed an AEM EBC and cannot regulate boost.I do not have the alarm or scramble boost hooked up, aka grounded. I am running a Lindsey racing waste gate. I have the spring pressure set to 5 and I have tried setting the duty cycle to 10, 65 and 90. Each time I make a run boost just keeps climbing.
Though I am confident I had the vacuum lines from the waste gate connected to proper side of the solenoid, I switched the vacuum lines, repeated the duty cycle process, all to no avail.
I traced all of the vacuum lines and all are connected and secured with zip ties to prevent blow off.
The gauge appears to be working as I am able to scroll through and set each parameter.
Any ideas?
Any ideas?
