Excessive Negative Camber
Old 10-07-2013, 05:37 PM
Gawernator
Gawernator's Avatar
Thanks much for all tips
Old 10-07-2013, 06:19 PM
Aero426
Aero426's Avatar
To measure the studs on the shock tower, the distance from inside front stud to inside front stud is 852mm, or 33.5". Measure to the center of each stud.
Old 10-07-2013, 10:15 PM
Gawernator
Gawernator's Avatar
Thanks Aero!
Old 10-07-2013, 11:17 PM
doc_
doc_'s Avatar
I decided to see how well my car could hold up to a curb at 50 mph. Closest I could get to alignment was 2 degrees off an eccentric. It is possible that your strut is tweeked as well, It not always an easy thing to spot such a subtle difference with your eye, especially if its still installed
Old 10-08-2013, 12:30 AM
Gawernator
Gawernator's Avatar
Do you have insert type struts?
Quick Reply: Excessive Negative Camber
