Dash gremlins
Dash gremlins
My odometer and tack have need a tap on top of the dash to get going, and I've just lived with it so far, but tonite the left side lights went out so I pulled the dash.
First question - how do you get the lights out.
Second question - everything seemed tight when I unplugged the connection to the gauges and they seemed tight so I'm not sure what I'm looking for.
Btw I read clarks info on the bulbs but it does tell how to get them out. I assume you twist, but which way? Or is there another way they come out?
Ok I got the lights out but everything looks fine. The filament is not broken. What now?
If I tap the dash to get the odo and tach to work where would I look or do? Again the connector was on good and not loose.
the lights may have developed a bad connection, just twisting would fix it - check with ohmmeter or apply 12VDC to be sure lights work. It can also be the dimmer acting up.
Speedo and tack become sticky with age, this is a mechanical issue, not electrical - you can take gauges apart, clean the pivots with suitable solvents and reassemble, or you can live with it.
Pulling the needles off is actually pretty easy, especially if you have delicate hands like I do haha. The trick is to make sure you are careful with the needle because the very thin metal will bend easily.
pull the needle, unscrew face, unscrew bearing bracket, remove the meter movement (carefully), clean the shaft, clean the bearings, reassemble. I don't think they are lubed in any way, that would just attract dust and get sticky.
meter pointer goes onto a splined shaft, or onto the thin movement shaft - just align with zero when at rest and gently press on.
So last night I traced the power lines in the electrical sheet and what it looks like to my untrained electrical eye is the lights are daisy chained together with what I assume I power lead and the common lead with off shoot of other branches that go to other components in the dash - though I may have power and common flip flopped.
My issue is the far right light works (and maybe the middle light, not sure on that one), the one closest to the pin connector, but the far left light doesn't work. However all the gauges work. So I'm guessing I have one of three situations: 1 - the light simply needs replacing, though my ohm meter reads the same on the known working light and the suspected non working light, 2 - the light simply needs twisting to make a connection like a previous poster suggested, or 3 - there is a break most likely in an electrical route causing the light to fail. However I cannot find a break anywhere. In fact the pin connectors and the electrical sheet look brand new other than the fact that little circular pieces of paper which cover some holes have come off or look wrinkled where they are attached.
If it turns out to be number 3 (broken circuit) where can one get that replaced?
