944 solenoid
I have just bought a a 1986 porche 944 NA and the first thing to do out is the starter. I purchased a rebuild bosch starter at car quest and now a week later i forgot how the solenoid connections went. I have a large black wire and a slightly smaller wire that are probably the hot wire and ignition wire and there is one other wire which is much smaller and is red. I cannot remember where that wire leads. The bosch solenoid has one bolt longer in height and another one that is the same width that goes to the starter. And then there is a bolt for the smaller red wire. My question is what should connect to the larger long bolt and should anything be attached to the bolt that goes to the starter.
