Oil Cooler and Seals
Hi Everyone:
I have a 86 944 Turbo, it is acting up and needs new seals on different parts of the engine. I just had the front engine seals done and the rear cam housing done about 6 months ago.
I was told that the Oil Cooler seal is leaking into my coolant, is this easy enough to do my self and if so how?
Go to:
944 FAQ and Do It Yourself Index
Link to section 7 - Oil Cooler Seal Replacement
It says it should take 45 minutes, but it took me the better part of a day. This was due to my inexperience, many runs to the hardware store for tools, and some really stubborn bolts. I also replaced the oil pressure switch and sender.
Label everything and take your time. Get a Haynes manual or a factory manual (or both). They are lifesavers.
Good Luck!
Good Luck!
Ahmet,
Ok, you're correct, there is no exchanger within the housing, but there are still seals in there. I just replaced mine last December. If they go, the results are still the same.
