How much R134A needed?
I'm gonna give recharging my AC system a shot...how much R134A do I need?
It was converted several years ago by the 1st owner...
How well do the conversion kits work? I just bit the bullet and refilled with R12 ($215, IIRC) because all the A/C guys I talked to said that the conversions don't ever blow quite as cold.
Semper Fi
Cpl SH Won
Wpns Co, 2nd Bn, 24th Marines
Semper Fi
Cpl SH Won
Adrial,
I am almost positive that the stock R-12 amount is 33 oz. It should say what the capacity is inside your hood on the left side just aft of the A/C dryer. There should be a sticker on the fender well. So, 80-85% of 33oz is 26.4-28.05oz.
That sounds about right but I would defer to Bob S. He is an A/C tech and basically the "man" when it comes to A/C. So go with what he tells you.
Regards,
Max
Regards,
Max
You can convert quite easily. You need to:
1. Take your compressor out.
2. Drain your compressor of old oil.
3. Install new oil
4. Replace drier with correct R134a unit
5. reinstall compressor
6. Have SHOP vaccum down your system
7. Have SHOP fill with R134a, buying 12oz cans at G.I. Joes will not allow you to measure accurately.
3. Install new oil
Deer Slayer
Don't waste your time with that R134A stuff. Use the R-951. It will make your car much faster, unless you already drive a 951. Don't use the R-928, it is too heavy, and for Heaven's sake don't use the R-911 unless you want to have engine cooling problems.
Thaddeus
Thaddeus
I converted my 1983 944 with 24 oz of R-134A and just dumped in the oil conversion. No expansion valve change, no oil purge. It blows as cold as the R-12 did and is still going strong. I would have drained the system, but my compressor leaks anyway.
