slight overheat
Lifetime Member
Lifetime Member
Guys,
Last night it was about 55, and I had her out driving home from the airport.
Near home, I noticed that the temp gauge was just above the first mark, and it never gets above that, especially on a cool night like tonight. It didn't get much higher.
Today it did the same thing, and it's about 75.
I had the lower radiator hose and thermostat replaced in June I think. The right fan comes on at the appropriate times and stays on to cool the engine. Pretty sure the left fan comes on with the A/C.
Any ideas? I'd like it to be back to normal, nice and cool.
TIA
-Matt
TIA
-Matt
Matt,
The problem is you running it into the rev limiter. JK.
Mike had a problem a while back like that. My car has started running warm as well. He had to change a switch (ask him) of some sort and it started working fine. Is it when you are cruising along as well? If it is then that is a horse of a different color. Do the stupid things like check your antifreeze. Maybe the thermostat, I hope not.
BTW, it is raining here, imagine that, so no land speed record tonight. Maybe tomorrow.
Lifetime Member
Lifetime Member
Ok I am an idiot. The left fan doesn't come on at all. (For some reason I thought they worked seperately) It doesn't even come on when I turn the A/C on. Most likely this is the problem. Yes, it has plent of anti-freeze and no leaks. It's been smack dab in the middle between MAX and MIN for 4 months now.
Fan switch thingy maybe? Skip? Help?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Matt
-Matt
I was under the impression that both fans don't always run together. I am not sure but I understood that both fans would come on when the temp came up or the A/C was turned on (in anticipation of high temps) due to the A/C.
Not sure though.
Max
Not sure though.
Max
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
On my 87 951 - both fans ALWAYS run when the car is running. When the car gets "hot" - both fans kick into high-speed mode and just run faster.
I suspect you have either a bad fan/temperature switch, or a bad fan.
Greg
Greg
