tune-up 944 NA
There's a limited amount you can doto a 944, in the classic sense of "tune-up."
Plugs, & if needed or questionable, wires, cap & rotor.
Timing is controlled by DME, so you don't adjust it. No condensor or points (my age is showing....).
Check air filter & fluids. As Tabor said, clean throttle body if needed (likely). Maybe a can of fuel system cleaner. Inspect belts & hoses. R&R fuel filter unless you know when it was done. Maybe replace wiper blades? Check tire pressures.
What have we missed?
Take a test drive. Grin _real_ big.
Jim, frequent grinner...
