Starting gets difficult...
Hi people,
since 3 days the starting of my 944S2 is getting more and more difficult.It takes longer befor ignition kicks in and it appears to be less powerfull.
I am afraid it wont start the next morning....
What can it be that makes it dying slowly? Voltmeter readings are fine while i am driving....
Thanks,
Nobbi
Thanks,
Nobbi
weak battery will cause slow cranking. so will bad ground to engine, bad connections to battery, and a plethora of other things. check battery voltage while cranking using a voltmeter at the battery, then check again measuring voltage at starter motor
