Intro to our 944 LeMons!
Awesome. Any chance there are markings on either the crank or the pistons that will identify if they are indeed 'the good stuff'? I have a feeling we're going to end up doing some bottom end work, but easy identifiers that don't require removing the mains would be nice.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
https://rennlist.com/forums/924-931-...questions.html
Boom! That should hopefully inform you as to what you've got.
Here you are Healey, here's more about our car: https://rennlist.com/forums/924-931-...light=chumpcar
Obviously, we used the ChumpCar's "approved $500 car" rule, because buying a few new parts puts you over the $500 LeMons budget. Our goal was to make a reliable car that we could give lots of noobs racing seat-time. So we rebuilt the brakes, replaced the wheel bearings, replaced the CV joints, it needed a new starter and fuel pump, replaced the clutch and we had to rebuild an engine (which, we used parts from 3 other engines... but used new gaskets, seals, bearings, rings, etc.)
With the safety equipment, you can imagine that the price crept over $500. Even ten times that... even more.
