968 Brake Caliper Rebuild
Hey thx for the input on the button head screw size. It's been a number of years since I was rebuilding calipers and clearly the consumption of adult beverages since then has had an impact on my ability to recall with solid accuracy :-)
Yes, M6 x 12 sounds correct.
I'm surprised you were able to get the larger bolts that hold the two halves together out. I know when Brembo assembled those calipers they did so with the intention the halves would never be split apart. There's some pretty hefty loctite on those bolts!
Well.. There was no loctite on those bolts at all! But getting them out was a pain in the *ss because of the old and soft metal the allen heads just parted when i started to turn them!
