ALLDATA
I just found out that I have access to ALLDATA through college. If anybody has anything you wish for me to look up, let me know and I will as soon as I can. If you don't know what ALLDATA is then ask.
Tim - I'm just curious about how many service bulletins there actually are for the 951... I was going to get a subscription, based on rumors that there were HUNDREDS, but am waiting to find out if that is the case...
Based on your evaluation, is a subscription worth it???
WOW, there are HUNDREDS of them, literally. Not sure whether or not this will come out right, but if it does, just let me know which ones you want to see and I will try to get them. Hey the time is 9:44...sorry
99 01 991105 Year 2000 Readiness
9068 990113 Requesting Vehicle Security Codes
8703 971001 Climate Control System-Refrigerant 134a Use
29604 960711 Sulfur-Like Smell from Exhaust System
89602 960606 Use of Correct A/C Refrigerant
89501 951219 Retrofitting R12 A/C System to R134
99505 950928 Modify Replacement Circuit Board for Fuel Gauge Function
9504 950323 Paint Manual Supplements (WKD 482 620)
TOOLS9502 950321 Quick Scope Plus
809501 950126 Automotive Refrigerant Identifier
X9402 941227 Ordering VIN Plates, Certification and Emission Labels
LIT9406 941117 Microfiche & Supplies, Update 2
19408 940830 Approved Anti-Freeze
LIT9402 940719 Technical Information Books
LIT9410 940505 Minimum Literature Inventory
LIT9406 940329 Microfiche & Supplies
69403 940324 Mixing Windshield Cement
LIT9404 940127 Workshop Repair - Manuals
09401 940125 Approximate Fluid Capacities-All Models From 1985
LIT9402 940111 Technical Information Books, Update 1
LIT9401 940106 Technical Specification Books, Update
49314 931221 Tire Manufacturer Contacts
99310 931221 Wiper Motor Cover
TOOLS9303 930921 Diagnostic Testers
19305 930921 Cooling Fan Motor
59302 930812 Water Entry Into Rear Hatch Area (Coupe Only)
EQUIP9303 930729 Auto Scopemeter & Engine Analyzer
49308 930518 Power Steering Gear - Diagnosis
49305 930415 Installation of 18 Inch Wheels Not Approved By Porsche
49305 930323 18 Inch Wheels Not Approved
99303 930318 Correct Wiper Blade Application
09301 930218 Centering Adapters For Stationary Wheel Balancers
89208 921222 A/C Oil Filling Capacities
89205 921203 New Sealing O-Rings For A/C System
49205 921203 Groaning Noise From Front Brakes.
9201 921119 Technical Information Books
19209 921103 Cylinder Head Gaskets and Machining Cylinder Heads
99203 920929 Poor Electrical Pin/Ground Lug Connections
29204 920929 Battery Discharging
LIT9201 920625 Techincal Information Booklets
19207 920417 Engine Oils That Minimize Carbon Build-Up
LIT9201 920403 Technical Information Booklets
LIT9203 920403 Valid Service Bulletins
19204 920320 Toothed Engine Belts Handling
WARR9210 920320 Tampering With Emission Control System
49203 920310 Brake Disc and Wheel Hub Run-Out
X9201 920204 Purchasing VIN Plates, Certification and Emission Labels
LIT9201 920110 Technical Information Booklets
LIT9104 911220 Workshop Repair Manuals
49104 911122 Summer Tire/Wheel Rim Summary
49101 911122 Winter Tire/Wheel Rim Summary
ATRATB078 911101 How To Use A Pressure Gauge - Automatic Trans.
LIT9101 911008 Technical Specification Books
LIT9109 910823 Literature Inventory Minimum Requirement
19110 910730 Coolant Pump Leak Diagnosing
99104 910730 Porsche Radios and CD Players Requiring Security Codes
29102 910614 Spark Plug Threads Should Be Clean and DRY
89102 910517 Substitutes For R-12 Refrigerant
19105 910517 Oil In the Cooling System
19104 910326 Valve Seal Replacement
TOOLS9103 910322 Porsche Special Tools
TOOLS9102 910322 Rebuilt and Exchange Program For 9201 and 9268 Tools
WARR9102 910312 Microfiche Tips, Actual Time Diagnosis Time
X9101 910115 Purchasing VIN Plates, Certification and Emission Labels
TRAIN9101 910115 Training Certification Expiration
49011 901214 Chrome Plating Aluminum Wheels
LIT9004 901204 Technical Information Booklets Currently Available
LIT9013 901119 Updated Maintenance Checklist Countermat
29009 901113 Prevent Gas Cap Lock From Being Used to Duplicate Ignition Key
19011 901113 New Type Engine Mount
89002 901030 Modified Air Regulation Controls
29008 901009 Use of Non-Approved Microchips
29007 901009 CO Sample Pipe
19017 901009 Engine Oil Pressure Relief Valve Description
ATRATB028 901001 Engine Testing With A Vacuum Gauge - Auto Trans.
59002 900918 Wiper Motor Hole In the Rear Hatch Glass Changed
49006 900814 Power Steering Pump System Cleaning
ATI080190 900801 Twenty-Third Supplement of the Advanced Technical Information
19014 900706 Engine Repairs Maintenance Follow-Up Service
LIT9008 900629 Technical/Literature Subscription Service
LIT9007 900629 Useful Guides For Technical Specification
49013 900629 Replacement Pumps Damaged Due to Foreign Material
19016 900629 Approved Camshaft Drive Belts
LIT9006 900622 Supplements That Have Been Issued to Date
79002 900622 Leather Upholstery Reconditioning
99003 900622 Telephone Installation Instructions
WARR9012 900529 Defects From Modifications to Electrical System
19014 900508 Connecting Rod Nuts Supplied As Spare Parts Incorrectly Made
LIT9005 900504 Wkd 481 821 Manual Supplement
EQUIP9001 900504 Celette Collision Repair Systems
EQUIP9002 900504 Wheel Alignment Equipment
29001 900410 Recall L01 - Replacement of Fuel Hose/Rail
WARR9009 900406 Special Colored Warranty Mailing Envelopes
LIT9006 900406 Printing Cycle For Dealer Parts Submission Report
49004 900403 Latest Winter Tire and Wheel Rim Recommendations
NHTSA90V061000 900330 Fuel: Fuel Injection
9005 900320 Access Warranty Start Dates and Recall Inquiry
TOOLS9003 900320 Compressor Seal Replacement
ATRATB9002006 900201 Automatic Transmission Fluid
LIT9003 900126 Currently Valid Literature Bulletins
19005 900126 Sealing of Oil Pan
98906 891215 Routing and Securing of Electrical Harnesses
38903 891215 Transmission Fluids - Specifications
48910 891122 VR-Rated Summer Tires
38906 891020 Hydraulic Clutch - Air In System
48912 891020 Stabilizer Bar - Modification
48911 891020 Emergency Brake Shoe Retaining System
48906 891006 Brake Squeak
ATRATB8930 891001 Automatic Transmission Math Part 2
18907 890915 SST P200A - Adaptation For Oil Cooler Testing
ATRATB8927 890901 20 Steps To successful Auto Transmission Repair
88902 890901 Refrigerant Recovery/Recycling
ATRATB8923 890801 Automatic Transmission Math Formulas
18910 890707 Timing Belt Cover - Ventilation System Change
48907 890630 Brake Calipers With Improved Piston Seals
18909 890616 Exhaust Valves/Stem Seals - Modified
18905 890505 Motor Oils That Minimize Carbon Build-Up
48901 890421 Brake Pulling/Brake Caliper Sliding Lubricant
48905 890421 Power Steering Pressure Hose Routing
98902 890414 Glove Compartment Light Wire Routing
18904 890317 Oil Cooler/Oil Pressure Relief Valve Repair Guide
MICRO8901 890120 New Microfiche Issues
18903 890120 Radiator Fan Switch - Improved
18901 890113 Checking Camshaft Drive For Damage
48813 881230 Wheel/Tire General Information
48812 881230 Winter Tire/Wheel Rim Summary
LIT8803 881213 Technical Information Booklets
48810 881118 Brake Pads Without Asbestos
68807 881021 Windshield Sealing
48809 881021 New CV Joint Grease
LIT8802 881007 Supplements, 944 Workshop Manual (Wkd 481 821)
LIT8814 880923 Video Service Information
28805 880923 Spark Plugs
28806 880923 Survey of DME, LH/Ezf and LH/EZK Control Units
WARR8810 880805 Revised Labor Operations and Repair Times
68803 880610 Sun Roof - Modification
WARR8805 880422 1986 Power Train Coverages
18804 880408 Poly Rib Belt Tensioning Procedure
LIT8809 880311 Update for Emission Equipment and Tune-Up Specs. Booklet
38801 880212 Determining Synchronizing Ring Damage
18722 871231 Machining Valve Seats and Checking Valve Guides On 4 Valve CYL.
48701 871120 Wheel Balancing
48709 871026 Brake Pad Installation Hardware
28711 870921 New Exhaust Manifold and Exhaust Cross Pipe
18720 870904 Radiator Plugged From Corrosion
ATRATB8754 870901 All Automatics - Front Bushing Wear
ATRATB8748 870801 Metal Sealing Rings - Automatic Transmissions
18717 870731 Turbo Oil Supply O-Ring
LIT8710 870724 Valid Literature Bulletins
18716 870723 Oil Pressure Relief Valve
LIT8709 870626 Workshop Manuals
18713 870622 Installing New Type Coolant Pump
18710 870603 Radiator Thermoswitch Mounting Modified
18709 870515 Engine Main Bearing Torque Changed For Pre - 1987 Models
18707 870506 Improved Oil Cooler Mounting
18703 870306 Tightening Procedure For Cylinder Heads
18704 870220 Installing New Type Oil Pressure Relief Valve When Repairing OL
48704 870220 Brake Pad Application
18702 870128 Short Block Installation Modifications
18701 870102 Cam Belt Tensioner Nut Torque -All Models Through 1986
18626 861219 Hydraulic Lifter Noise, 16 Valve Engine
LIT8632 861216 Technical/Literature Bulletins Subscription
18629 861216 Corrosion In the Cooling System
88605 861212 Filling of A/C System
18625 861212 Oil Pump Modification
28609 861212 Exhaust Manifold R&I Procedure
48612 861212 ABS Test Procedure Update
98608 861212 Service Installation of Center Mounted Brake Light On Porsche 9
98611 861212 Front Turn Signal Lamp Moisture
48611 861126 Bridgestone R E 71 Tires
LIT8631 861126 Repairing Cars With Beaded Paint Finish
EQUIP8601 861121 Sun Sleuth Two
EQUIP8602 861121 Sun Air-Kare
98610 861121 Economy Gauge
08604 861110 Winterization
98609 861110 Relay Location - 1987 Models
88604 861031 Air Conditioning Oil Filling Capacities
78602 861031 Power Seat Backrest Control
38607 861031 Modified Release Bearing
98604 861024 Testing of Instruments
48610 861024 Testing Steering Gear For Damage
48609 861024 Rear Axle Nut Torque
18617 861017 Flushing Cooling System
18620 861017 Camshaft Drive Belt Adjustment
78601 861017 Seat Heating System
68607 861017 Modifications of Lifting Roof
38606 861017 Clutch Servo Spring
18621 861017 Heat Shield For Cars With Catalytic Converter
68604 861017 Outside Mirrors
28606 861017 Engine Oil Level
LIT8630 861010 Warranty Return Parts Tag/Label
28603 860919 Intake System Cleaning After Engine Damage
18615 860919 Determining Coolant Leaks
28604 860919 Steering Lock Cylinder
28605 860919 Catalytic Converter
68603 860919 Door Window Opening Lift Rail
LIT8628 860915 944 Workshop Manual, Supplement VI
EQUIP8603 860912 Vbm Challenger 2 Vehicle Lift
LIT8626 860809 944 Workshop Manual, Supplement VII
98601 860709 Relay Layout On the Central Electric Board
18614 860709 Cleaning of Main Oil Channel In Engine
LIT8623 860701 Electrical Troubleshooting Logic
CMPG28601 860625 Replacement of Fuel Return Line Hose
08602 860625 Maintenance Requirements MY 1986
28601 860625 Battery Discharging
58606 860625 Ignition Keys
LIT8612 860530 Wiring Diagrams Booklet Model Year 86
58601 860527 Rear Lid Unlocking Procedures
LIT8611 860520 Service Bulletin Binders
18607 860425 Checking the Hydro-Engine Mounts
LIT8609 860423 Spine Labels, Technical Bulletin Book Pna 000028
LIT8606 860423 Ordering Emission and Tune Up Specifications
88602 860327 Low Pressure Switch - A/C System
48604 860327 Shock Absorbers - M.Y. 1986
58603 860327 Paint Identification
88601 860319 Freon Temperature Switch
18609 860314 Modification of Oil Filter Wrench - P9204
18605 860228 Repairs to Correct Slow Buildup of Oil Pressure
08601 860220 Front Springs-Blocked For Shipping
18601 860214 Drive Belt Checking and Adjusting Values
LIT8602 860109 Model Year 86 Introductory Information
18527 851210 Basic Emission Equipment and Tune-Up Specifications
18530 851206 Torquing the Cylinder Head
58502 851206 Rear Window
08505 851202 Maintenance Requirements - M.Y. 1986
18523 850924 Tune-Up Specifications For M.Y. 86
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Guys,
If you go to www.alldata.com you can get these lists of service bulletins free of charge from their web site. If you want to see the actual TSBs, then you have to pay by yearly subscription for each individual type. It is a good investment. You can learn quite a lot. Wiring diagrams are included in the deal,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
Originally posted by Adrian:
<STRONG>Guys,
Ciao,
Adrian
911C4</STRONG>
<STRONG>Guys,
Ciao,
Adrian
911C4</STRONG>
Oh, and a lot of those service bullitens go with the other year cars also.
