Rennbay Headlight Harness???
I recently purchased a used Rennbay Headlight wiring harness with relays from someone on this forum. Although I did not receive instructions, the install looks fairly straight forward.
I'm looking for suggestions of where to mount the relays and fuse holder bracket.
Any advice or pictures of install would be greatly appreciated.
Do what thirdgen did, I used the ignitor mount for the plate on my S, which is really only for the 16v cars. If you don't mount them to a plate and keep them off the frame rail they will stay wet and short after a while. Mount them up!
I wsh I took before pictures. I've also got the e code h4 housings and the difference is staggering. Before I did the upgrade I avoided driving at night due to poor visibility. Now lighting is every bit as good as a new car with standard lights.
Also ignore the dirty car I posted. It was cleaned up when I did the AC removal.
