944 Firewall flex
944 Firewall flex
I addressed this a few years back but I now must deal with it.. My firewall at the clutch master cylinder is cracked and flexing.. I noted that someone makes a plate to be welded in there. Does anyone know where I can contact this person or does someone have a reasonable alternative?
Personal email = GRSGI@YAHOO.COM
Gordon
(Note: cross posted to Pelican)
Gordon
Flash (bob) over on Pelican has made something similar. I cant find the link to his site, might wanna PM him for details.
Thanks for the heads up!
Edit: I looked up the user flash and there is a guy with that name but he only has 1 post...ever. Is there something else I should search for?
Edit 2: found him...Flash968...thanks!
Cole.. I've seen this on many 944's and now many 968's. It is normally the result of an improper clutch being installed. I've owned my 944 since 2002 and have used Pelican to a great extent rather than Rennlist (I am not a new user by any means). Look at the history of each site and you will see how widespread this problem is..
I happens, its nowhere even close to "all" as mentioned above.
I am sure that he meant all owners "may" face.. There really is no way anyone can foresee who would fall victim.. I am surprised that the 968 would become susceptible though..
Question, I've owned 3 924's (old ones) and I never heard of this happening to a 924.. Have you?
Yeah. Obviously it hadn't been a large documented problem with 944/951 by the time they designed the 968. Porsche is pretty good at addressing known issues in design.
I'm sure age, location and type of use (heavy stop n go) can be big contributors.
...Um......So that actually makes me right That is was such a non issue that Porsche didn't see a need for a change and actually caused a problem with the 968!
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
w/ 968s... don't have numbers but.... it's a problem.
update:
now reading the thread below your posting....
i'm sure it's got plenty to do with the 968's clutch being so stiff. makes me cringe.
