951 turbo water pump won't stop running
The water pump for the turbo on my 951 won't turn off when I turn the car off. It's kind of a problem because it drains the battery. Has anyone had this happen? Could it be a bad switch?
Originally posted by 951juden:
<STRONG>The water pump for the turbo on my 951 won't turn off when I turn the car off. It's kind of a problem because it drains the battery. Has anyone had this happen? Could it be a bad switch?</STRONG>
engine off, pulley wont turn
do you mean the fan ??
Try disconnection the sensor, it's the single wire sensor on the metal water pipe to the turbo, just inder the right side on the intake. It will then default to about 30 seconds on every time you shut down. If your still running disconnect the wires to the pump until you figure out the problem.
That pump is not doing much to cool the turbo, as long as your not hammering it all day you will be fine until you want to deal with it.
Originally posted by adrian jaye:
<STRONG>
is'nt the waterpump driven by a pulley ???
do you mean the fan ??</STRONG>
<STRONG>
