Oil pump pinion protusion from oil pump
Hey guys. I have the oilpan off, just changed the rod bearings (#2 didn't look too good compared to all the other bearings). I removed the oil pump. Upon replacing it, I noticed that the oil pump pinion seems to be sticking out from the oil seal about 1 mm. Is this normal or should the pinion be flush with oil pump/front main seal? I imagine that the oil pump pinion is bottomed at the stepped portion of the crank, but I would rather ask than disassemble.
BTW, don't worry... the belt covers are coming back on before the car gets on the road.
-Steve
1986 951 107k
-Steve
1986 951 107k
Not sure if this is normal or not, but I have to ask, Is the picture with the crank bolt properly torqued down to 155 ft-lbs??? If not, might account for the protrusion since the pinion is driven br friction with the crank pulley. I replaced my front seals this summer but I do not remember the orientation being flush or protruding.
HTH
HTH
Originally posted by Riff:
<STRONG>Not sure if this is normal or not, but I have to ask, Is the picture with the crank bolt properly torqued down to 155 ft-lbs??? If not, might account for the protrusion since the pinion is driven br friction with the crank pulley. I replaced my front seals this summer but I do not remember the orientation being flush or protruding.
HTH</STRONG>
HTH</STRONG>
-Steve
