Re-powering rack
I've got an 84 NA and the PO had disconnected the PS pump and reservoir. I want to repower the rack.
I've got the rebuild kit for the pump and a new reservoir. I also have most of the other pieces, except a few washers, nuts and one of the sleeves. I seem to recall that the PO said that a bracket was missing and would need to be replaced. The only bracket I see on the PET is 944 101 147 01. I haven't bought it yet, but I am unclear on where this bracket goes.
Here is a pic of what I am looking at. What am I missing?
Thanks,
Tim
Thanks,
Tim
Thanks, I I found Sonnen's site and will check with them on Monday.
I guess my confusion is that it looks like the pump will mount up without that bracket. It looks like the upper right side of the pump mounts up just using the bolts and sleeves. So I couldn't tell where exactly that bracket went.
http://www.autohausaz.com/porsche-au...placement.html
Check out the photo. The bracket is the yellow zinc piece that bolts to the pump. All it does is give you the mounting point for the tensioner.
