The saga continues... (coolant leak)
Lifetime Member
Lifetime Member
Well, I did the pressure (10 psi) test like you guys said, and I found a leak. I can't tell where it is coming from - it looks like it is coming from inbetween the a/c cooling and the radiator...? It's a slow dripping leak, and seeping out, so I can't quite tell. The line goes all the way up to near the top.
I took the bumper off, and I'm taking the front valence off to see what I can get to...to see what I can see.
Is there a part around there that get's a leak commonly? The tube that goes by the alternator belt looks good.
Thanks,
Matt
Thanks,
Matt
The upper radiator hose is right there - sort of behind the radiator and next to the driver's side headlight. They should be replaced quasi-regularly, every 5 years or so would be a good precaution.
If you have a 951 - there are a zillion other little hoses around there, leading to/from a cross-over coolant pipe, the turbo coolant pump, etc.
Greg
Greg
Ya know, it could also be the plastic end of your radiator starting to split away from the metal part. Leaks here usually only show up under pressure by running down the crack/seam of the radiator and dripping off the bottom.
Greg
Greg
Matt: There are no hoses "between" the radiator and the A/C heat exchanger. The only thing I can think of in that area might be a weak seam in the radiator itself. That would spray under high heat conditions.
You might want to pressure test the radiator separately to eliminate this as a potential problem.
BTW..Who says it doesn't snow in Arizona? I'm looking at the white capped mts about ten miles away. That's where I LIKE to see snow!!
Bob S. (enjoying his first winter away from upstate NY)
Lifetime Member
Lifetime Member
Originally posted by Greg Hammond:
<STRONG>Ya know, it could also be the plastic end of your radiator starting to split away from the metal part. Leaks here usually only show up under pressure by running down the crack/seam of the radiator and dripping off the bottom.
Greg</STRONG>
Greg</STRONG>
And it's an NA, not a Turbo.
Thanks,
Matt
