Mirror wind noise
Old 07-23-2001, 06:27 PM
MAS
MAS's Avatar
Post Mirror wind noise
For some reason, the driver's side mirror on my 87 924S makes a lot of wind noise (resistance) when I drive at even moderate speeds. I'm not sure why this should be, because both mirrors are stock, are attatched properly, and have never been damaged.
Is there any way to fix (or minimize) this?
-MAS
Old 07-24-2001, 06:55 AM
MAS
MAS's Avatar
Post
Does anyone here have the same problem? No? As the wind noise is quite loud. I can't believe that this is the way that Porsche set the mirror(s) up.
-MAS
Old 07-24-2001, 09:18 AM
Dave
Dave's Avatar
Post
You could upgrade to aero style mirrors, if it bothers you that much. I ride around with the windows down and sunroof off, so I expect wind noise.
Old 07-24-2001, 12:38 PM
Roland Kunz
Roland Kunz's Avatar
Post
Hello
First to look is if the hex bolt hole is filled with a small plasic plug.
Grüsse
Old 07-24-2001, 06:44 PM
rangelica
rangelica's Avatar
Post
Yes the wind noise is loud, annoying and common. Try a set of mirror bras, it will quiet the wind noise.
Rick
'86 951
Quick Reply: Mirror wind noise
