Floor-mat clips.
I was wondering where I could get new clips that go from the seat-rails to the underside of the floor-mats to keep them from sliding over the peddles. Thanks
Did not know these clips exsisted
I used stuf called 'klittenband'in Dutch.
It is a two layer strip, one with nylon "hooks" and one with rings.
Both layers have an adhesive on it.
(Mum knows wat I mean, it is used as fastener for clothing and bags etc. as well)
Apply the one with "rings"on the floor.
Curtain hooks can be put from the mat to the rug and will work great. If you have the inclination sew a loop in the bak of the mat for the curtain hook to slide into. This will make them easier to remove. Also I think he means velcro which is fine for the foot rest but tends not to hold and the backing glue tends to stop working after a while.
They sell special floor mat clips which clip onto the floormat and then you insert secure it into the floor carpeting with tow little pointed protrusions. They work great and you can pick them up for about $1.50 at Wall Mart or Pep Boys.
