front panel removal
can anyone give directions how to remove the front panel on a na. mine needs to come off and i cant seem to find anything on it. thanks!
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
i'm not sure how much it will differ from removing the front nose panel of a 951, but Turbo Tim's website has a simple set of directions on how to do so...www.speedforceracing.com
find the link to the vented nose panel or SFR intercooler.
i've done it before which means almost anyone can...pretty straight forward.
hope this helps...good luck
4 screws on top under hood, 2 under each light, one on each side under lights towards the center of the panel, and 1 bolt under each light on the fender side. pull rubber out from under lights and remove panel.
Never done a na, but it should be about the same
Good luck
Good luck
