Continuing looking for a vacuum leak... Only at idle
So, new Venturi hoses, vacuum lines, new vband for the bov, resealed the tb..... Did the intake pressure like on vans youtube video.... And: NO MORE LEAKS
The only small leak i have is at the aos, probably the 2 rubber seals, but i was told that this cant have an effect on vacuum pressure.
Started the car, same thing. The needle is above 0.4 bar and boost gauge is at -12psi
When the car gets warmer, the needle is slightly above 0.4bar, boost gauge at -15psi.
Engine runs ok
Went fore a drive, then at a red light, looked at my gauges and vacuum where PERFECT. Idle at 1000, -0.4bar, boost gauge at -18psi.... I said Yes!
BUT....
Checked everything again, and notice that tps was open on idle, i didn't adjusted right. Pushed on the cable to make it click, then still loosing vacuum (-14psi).....
SO.... If the tps is not closed perfectly at idle, the car runs fine, vacuums are perfect..... But if i set it correctly, i lose vacuum....
So what is my problem here?
Engine runs ok
BUT....
FOUND IT.
sticky icv. faaaaaack. Shot a ton of wd40 in it, now everything is back to normal.
At least my intake vacuum are perfect. -18/-19 psi at idle.... beautiful
