Sweet supercharger sound after timing belt job
Just finished a timing belt job on my '84 NA and now my car sounds like it has a sweet supercharger. I remember reading somewhere on here that it's usually caused by either the Alternator or Balance Shaft belts being over tightened. But I can't seem to find where I read that. Just wondering which belt I might need to back off a tad.
Be sure you have the required gap (0.5MM) between the belt and the idler roller at the lower balance shaft pulley. This is the biggest source of the supercharger sound if it is really pronounced.
Yeah, I've been driving with mine like that since the 60k service a little more than a year ago. A quick search here showed that it's not a problem, it's just an annoyance. I'm dropping the car off for the annual, and I'll have them make the adjustment while they have it.
Proprietoristicly Refined
I agree with turbodave--set the idler roller correctly--top and bottom.
J_AZ
Agree with the comments about setting the idler roller correctly. If it is spinning fast all the time while the car is idling then it will make a lot of noise. Correct me if I am wrong but I believe the roller is only there to stop the belt from flapping. Mine is set so that it only comes in contact when I first open the throttle, then the belt settles down once the roller does its job and stops it flapping.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Ryan Kennedy in Holly Hill (Daytona), FL did my belts/pullies/H20 pump back at the beginning of April.
same exact result with respect to the sweet whine.
Got Nothin'
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
