944 Turbo s
Does anyone have an opinion about what I should look for first regarding my front end? I have a 1988 Porsche Turbo S. The first 8 months I owned the car it was a garage queen. But, since, this car has turned into a daily driver. The front end bounces around and "hunts" for a track. It does not feel nearly as stable or confident as a Porsche should. Ideas of what could be wrong?
There is an active 944/951 crowd in Austin.
You should be able to hook up with someone here to have it looked at.
I would get it on a lift and check to see that none of the front rubber/bushings/etc
are not worn.
Easy to do. Just wiggle the tire/wheel while inspecting from underneath.
Mike
are not worn.
Mike
