Blender Door for an 83/944 WHERE IS IT??
It would appear that my Blender door is either stuck, in-op or whatever. Where can I find it because Im pretty damn sure that is why my AC is not blowing cold air. Can anybody help me on this one?
TIA
Carl 83/944
TIA
Carl 83/944
If you look under the dash, drivers side on the evap. housing you will see a rod coming from the control motor running to the blend door. This rod runs up and down.There may be a black cover over the motor and rod. Where the rod connects to the motor there is a white clip that hold the rod to the motor arm. That clip is most likely broken. Replace the clip and the problem is solved (hopefully).
