Do I need a special wrench to loosen the brake bleeder screws?
Deer Slayer
Dumb question, but I don't want to get under there and discover I need some weird 5 cornered socket or something...
tia
Thaddeus
tia
Thaddeus
did mine yesterday. i think i used an 8mm open-ended wrench. when working on the right side, i turned the wheel all the way to the left and vice versa for the left side.
I find SpeedBleeders makes things so much easier! http://www.smartcart.com/Paragon/cgi...m_num=944SBLDR
They make a special wrench for brakes. It has a slightly open end to allow tubing to pass through, but it is designed to really hug the bleeder. It does not have any of the extra corners (for lack of a better word) that are typically found on a closed end wrench and it has better grip than an open end wrench.
I have a whole set (about three wrenches) for all size brake fittings on my car.
Having stripped plenty bleed screws in the past, I highly recommend that you get one of these brake wrenches. Otherwise, you might need a good set of vise-grips.
They're called flare wrenches or flange wrenches or something like that. I have a set of larger sizes, but none small enough for brake bleeding. Instead, I use the box end of a combination wrench, then slide the tubing over the bleeder, Since you really only need to turn the bleeder 1/4 turn during the process, I set mine up so I can use it like the handle of a ball valve and don't need to reposition it.
