BMW Reference sensor question
What years and model BMW run the same spd and ref sensors as the 944 I heard they are a lot cheaper?
89 944 NA
87 944S project almost complete
85,1 944 DD
89 944 NA
85,1 944 DD
Proprietoristicly Refined
From pro member/mechanic PorscheDoc: 1988 BMW 535i or so:
https://rennlist.com/forums/8187462-post7.html
More info.
You can get the BMW sensors with black plastic ends-really cheap or the silver caped ends.
I prefer the silver caped ends.
https://rennlist.com/forums/924-931-...e-sensors.html
More links:
Sensor test after you see Clarks-Garage
https://rennlist.com/forums/9816630-post2.html
Removal is difficult if the sensor "O" ring is rotted---be very careful not to break the sensor in half.
GL
J_AZ
More info.
More links:
GL
J_AZ
I ordered mine through my shop at worldpac but you can get them from Partsgeek.com for like 80 bucks a sensor. Mine I wanna say was 88 535is which is a friend of mines track car. And they have longer wires because they go into the bottom of the e28s bell housing. Which is better because you can rout them out of the way and keep them away from heat so the dont get brittle. I use an old O2 sensors heat shrink/ heat shielding which is like a firebraid and protects them even further.
By the way Scott I buy all my parts OEM from parts geek/ worldpac They have all OEM and some aftermarket for amazingly cheap. I just two 86 turbo rear wheel bearing by *** for 40 bucks a pop!
After market sensors seem to be trouble free according ro the posts I've read here,so I ordered them through Lindsey Raciing for $40 bucks apiece! I will check out Parts Geek though for sure next time out!
