Is the relay diagram incorrect in the 1983 Owner's Manual?
On the Pelican web board I was told the relay diagram in the 1983 owner's manual is incorrect. As you may know I am having problems with my cooling and fresh air fans, and I have determined that it is somewhere in the fan circuit.
If the owner's manual is incorrect, what are the correct slots for the relays?
In particular, should the cooling fan relay be in slot #1 and the A/c relay in slot #3?
Thanks,
Jeremy
1983 Guards Red
Thanks,
Jeremy
1983 Guards Red
