Oil cooler seal change
I am changing the seals on my n/a oil cooler. The Rennlist procedure doesn't mention draining oil or coolent. I am about to take off the case. should I be draining coolent before I take the case off? Or just catch what comes out? Thanks!
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Anyone thinking of changing the seals? If so, good idea to drain the coolent out of the radiator first. You'll still get some, but not the flood I entertained!
The oil can stay in until after the runup. Not too bad to do. I found the bolts easiest to access from underneath. Took me a whole day, this being my first time. The tech page suggests 90 minutes.
sounds pretty fast for mere mortals. Good luck brave souls
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
