Gear shift lever assembly unexpected failure
I was pulling out of the parking garage the other day and the shifter started feeling a bit strange. All of a sudden, the shift lever was twirling around like a broken leg. The weld between the shift lever and the shift rod (the rod that extends back to the transaxle) just failed. This is the weld at the tip of the shift rod, that makes the female connection to the shift lever.
Now I have to pull this thing out and have it welded or braised. Anyone have any experience with removing a shift rod with the transaxle still in the car, etc.
Oh yeah, as I sat there wondering what to do, I pulled the shift boot off and took a look. It was apparant that the weld just gave way, so I grasped the shift rod and soon found out I could make the shifts by careful pulling and tugging on the ole rod. I drove home, on a rather long selected route with few stoplights, and never missed a shift. My fingers, however were rather chaffed and hot due to all the heat coming up through the opening.
Need some help figuring out how to pull out the rod and such. Any tips will be appreciated!
P (AKA "sharkdog")
P (AKA "sharkdog")
