Rusting CV Bolts
Driving the car in the winter? If not, then the bolts you got from pelican must not have been zinc'd.
But shouldn't need put anything on them, usually enough oil/grease weeps out of the CV boots and trans output shaft seals, that the bolts get a pretty good corrosion protection coating on their own.
While I was under the car yesterday ruining the rear suspension, I noticed that the CV bolts I replaced about a year ago are starting to rust. I had snapped the originals on both sides and replaced them with bolts I ordered from pelican. Now the heads, particularly where I'll need to jam the triplesquare tool are getting pretty rusty.
Has this happened to anyone else? Should I replace these CV bolts again now while there's still a chance I can get a tool in there to bite?
I guess maybe I should bite the bullet and buy the lockers.
Well, that's what bothers me. The bolts I originally took out didn't seem to be all that rusty either. Granted the majority had snapped and there was a lot of grease covering everything.
I left these bolts in a relatively clean condition when I left them. Maybe I should be coating them with grease or something.
