Spark Plug Recomendation?
3rd Gear
Time to change the plugs in my 86 944.
Any recomendations?
Currently using Bosch but open to something more high performance
thanks
Any recomendations?
thanks
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Like Paulyy says, NKG is a good brand. Just go for the standard ones.. NGK BPR6ES. NGK copper points burn hotter, but need to be replaced more often and they are cheaper.
Cheers,
Larry
Cheers,
Larry
I run the BPR6ES as the two above. They appear to be giving a good clean burn (confirmed when the head came off) and I've only ever had to make very minor changes when checking/changing the gaps.
