Wobbly engine help ???
Hi all,
This is gonna be a tricky one to describe so ill do me best. The problem happens when in first and pulling away from rest and only happens/is more noticeable on an incline. The problem is the car kinda shudders from rest the transmission or i dunno the engine feel well... juddery ... cant really describe it very well. I suspect maybe engine mount maybe some mouting point broken??? I will get under the car soon but it would be helpful to know where to look
Thanks for your time
Phil
85 944 NA
Phil
85 944 NA
hi all,
eric - no not at idle .. the change to 2nd is sometimes clunky so im guessing its clutch rather than mount.
Bob - couldnt tell you without ploughing through the service history ... i expect its clutch . Having this verified by local specialist tomorrow so ill let you know !
Cheers
Phil
Cheers
Phil
