'84 944 Fan vs. Hose
Old Jun 29, 2001 | 05:21 PM
Tim Rouse's Avatar
Tim Rouse
2nd Gear
Angry '84 944 Fan vs. Hose
Replaced radiator with 'better' one that ended up being thicker which puts high temp/ac fan into conflict with the water pump hose. Currently fan disconnected so as not to harm hose. Any ideas?
Old Jun 29, 2001 | 05:26 PM
Ahmet's Avatar
Ahmet
Post
Yes, check the radiator mounts, and brackets. If it's a Porsche part, it should not interfere. If you don't want to get into that, you can cut the hose to make a few cm shorter at the radiator (we're talking about the hose from the pump to the radiator right), as to avoid rubbing.
Until you do this, I suggest you only disconnect only the fan on the passanger side that rubs.
Ahmet
