944 with 968 Spoiler(Pic Request)
Got four pics here, both from RL members,hope they don't mine me passing them over to you.First one is from member "Modded Everything" car,the second set are from member( RK 951) car.Even if both car are not gold/kalahari beige yours should look almost the same with the 968s bridge spoiler.
I bought my 944 with the 968 hatch already installed. I don't think it fits too great, there is a visible gap, and I can reach my fingers through the top around the seal if I want to. There are a few drops that get by it if I drive in the rain. However, I really do like it and won't change it back if I don't have to.
I LOVE the way it looks but fear messing with success..
that is correct.
the 944S2 we drove in Germany in 1991 was a factory supplied car, owned by the factory. It had the bridge spoiler also. When we encountered 'test' vehicles around Weissach we noticed the 968 test mules also carried the same spoiler, but when asking anyone there at Weissach or Zuffenhausen about them, was given the total silent treatment.
I believe it was there at Weissach or it may have been at the Nurburgring during tire testing, I first saw a 968 with a nomenclature affixed to the back that also read 944S3.
Of course today, we now know how that played out ......
I like the bridge spoiler and have it on one of my cars. It lends an air of individuality to it that separates it from the others with the more commonly seen rubber fin/ spoiler.
Although the hatch will bolt up, you need to be aware there are some things you'll need to change to make it work correctly. The pin mounts on the 968 hatch don't have the seal on them - they have the seal on the body side. You can swap those out from your original hatch if they're in good condition, or you can buy the 968 gaskets instead (which requires drilling two holes for each one). The 968 also lacks the rubber gasket that goes across the back, which makes that gap look a bit bigger than what it is. You can take the gasket off your old hatch and use weatherstrip adhesive to attach it to the 968 hatch. That seal is normally pinched between the foam spoiler and the hatch keeping it in place which isn't there on the 968 hatch - hence the need for weatherstrip adhesive.
And lastly, you will no longer be able to get your key in the lock under the hatch - it hits the 3rd brake light.
Nashvegas (07-29-2024)
I do like the 968 spoiler on the 944, I could be wrong but I believe that te 91 US car came with it, or at least the 3 cars that I have seen had it With that said, I think that it would be too much trouble for me to change the rear hatch on my S2. Not to mention, possible leaks, squeaks and other foreign noises...it's hard enough to manage those with the current set up. But that's just my opinion.
OP, that's a nice looking spoiler, GLWS.
Im with you, i prefer my 944 to look like a period 944. That upgrade stuff is nice but its not the image i have in my head for my 944.
I'm undecided on the 968 door handles. My car came with them, but I'm not particularly fond of them or the original handles. Someone was working on MkII Golf door handles, which I think look better overall.
