Looking for Exhaust Manifold
Sorry for the x-post.
Hey guys, just found out there is a small hole in my turbo exhaust manifold for cylinders 1 and 4. Are there any aftermarket units that are better than stock? If not, does anyone know a good source to get it from?
Thanks.
Thanks.
Professor of Pending Projects
The only aftermarket items that I have seen for the Turbo are from B&B. At around US$1,000.00. Or you can replace them with original items (but I think this route is even more expensive) or try to find a good set of used ones.
Good luck. My car is in the same situation, with exhaust leaks coming from the exhaust manifolds, I was thinking of first trying to repair the old ones and see how much that lasted.
Just a thought for a repair. if the hole is easy enough to get at, and there is some meat to the metal. try using a pipe tap close to the hole size. and after tapping the hole insert a pipe plug... Just a thought.. good luck.
Ooop's sorry about this, is the pipe infront of the turbo? if it is you can NOT tap the hole without removing the pipe.. there will be a few curls of metal from the tap.. I do not think the turbo would appreciate the metal..
