"Switch Intake Pipe Cooling" location
Old Jul 12, 2001 | 01:05 AM
RCKinstler's Avatar
RCKinstler
Cruisin'
Question "Switch Intake Pipe Cooling" location
I am tracking down the cause of my radiator fans running constantly. Checking the
voltages going to the fan relay has revealed that the "AC" terminal is getting 12V constantly. I have the shop manual set and
it appears to me from the wiring diagram that two components can be applying this voltage. One is the dashboard A/C switch and the other is only identified as "Switch Intake Pipe Cooling". I believe that the A/C switch is not the voltage source, as the A/C would be running constantly, which it is not. I would like to know what the "Switch Intake Pipe Cooling" is or where it is found. Any suggestions?
