924 brake conversion ???
Done With Sidepatch
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
Someone must know cause I dont...
I'm in the middle of the conversion from disc/drum to 4 disc in a '78 924. The donor car is an '80 931. My question is the m471 plumbing (brake lines) the same as the '78 924? Do I have to change the brake lines to adapt to the '80 924 turbo master cylinder. I know the '78 and '80 master cylinders have the same diameters for front and rear as opposed to the 944 which is stepped at 23/19 mm and requires "X" plumbing for front and rear.
I believe I can use the same lines and just plug the clutch port.
What do you think....
Mike
Mike
heres what you need to do, leave the disc in the 931. Fix the 931 with the parts from the 924 and drive that because 2 more brake pads are not gonna be needed, unless you plann on tracking this car.... ohh well what do i know.
well i guess thats my less than $.02 do with it what you will.
