4 Degree Offset Cam Key
Today I got
My Custom Title
My Custom Title
Also, my father was worried it might have side affects such as burning the exhaust, etc.
Do all the 944 spec racers use advanced timing? If not why? I want more assurance that this mod is all good stuff.
Small Business Partner
Just look-up variable-valve-timing for more info on implementations of cam-phasing.
Spec-racers might not use it, because a lot might want/need as much high-RPM power as possible.
Hello All,
I have the cam housing off my 87 924S to replace a broken #4 exhaust springs. I’d had a 928 International 4 degree cam key on hand and figured this would be a good time to install it.
My question: has anyone had to file the new key to get it to fit? I have NOT done so yet, no have I applied and light hammer/drift tapping, but it sure looks like the new hi-po key is a hair too long for the (lozenge shaped) recess in the cam’s end.
Wisdom from the gurus would be most appreciated.
kind regards, John
kind regards, John
jeyjey (03-29-2022)
Is there another source for an offset key other than 928 Motorsports? $40 seems a bit high for a reengineered $5 OEM part.
