944 S2 16v cam chain removal?? Endless chain.
Ok, I've got the cover off and guide rails and gaskets etc ready to go. Only thing is that both the secondary drive chain and the new replacement chain are endless (i.e. no links). I've read that the chain tensioner guide rails takes an hour or so for the whole job. As the chains are endless though, the cam shafts will need to be removed and that makes the job much bigger. Have I bought the wrong replacement chain or is it a matter of splitting the chain and buying a link? Thanks.
yeah, but for a $10 chain, its worth the insurance to do. You could mark the timing belt on the cam gear, remove cams, change chain, replace cams, and install the belt.
I thought this would be the case. Thanks folks. I was hoping that there might be an aftermarket chain with removable link option.
dillon410021; When you marked the cam & belt etc did you also need to loosen the tensioner.. Or were you able to do the replacement by leaving the adjustment alone and tieing the sprocket up in some way?
Opinion/Support from those in the know please. Inspecting my current chain it is all solid. But the two brass-coloured linkages (which mark the sprockets upright position when in TDC) have a tiny bit of play. It is only these links that have any play..... is this normal?
the chains dont fail directly, it is rather that the tensioner pads get old, corners of them break off or the chain gets worn from time to time. When both happesn, the chain will sooner or later jump over a tooth of the gearwheel and that cause huge damage! Better be caeful!
cheeRS
Ken
cheeRS
Ken
