STUPID 944
7th Gear
STUPID 944
The problem is it wont start. we replaced the timing sensor and the coil and the starter and we tried to pull start it today and the engine locked up does anyone know what could be wrong with the stupid thing ?
Done With Sidepatch
Locked up ?...Do you mean it dosen't turn over...If the starter is working fine you may have a timing belt concern...Like valves bumping into pistons...Is is something like that ?????
Strong possibilities.... gasoline hydrolock in a cylinder from a leaky / stuck open injector &/or failed FPR.
Broken cam belt, piston hitting valve.
Pull plugs; put a socket & breaker bar on the crank pulley bolt; attempt to turn by hand in both directions.
Remove plastic cover from cam belt area & inspect while turning by hand.
Third possibility... excessive operator head space. Probably can't be fixed here.
Jim, just up from a nap after watching the Leonids... great show!
