Euro 944 in US with reg- buy or not?
I have an opportunity to buy a very clean 85.5 Euro 944. It has proper registration etc. is it risky to buy this vs. a USA car? It has the nice bumpers with built in fogs... Plus the 160hp? Thoughts?
I guess it depends on your states regulations. If it's already titled here then it shouldn't be an issue. I don't know if euro spec cars use many different parts than are on the US cars tho. Parts might be harder to get.
I have one. The VIN did not come up properly [mine is an '82] but they hand entered it in the computer and I was [am] fine.
Euro engine was toast, I put in an '86 US engine and was not too upset since it will run on regular where the Euro engine needs premium. I just ordered one of the Rogue MAF systems, should boost power up to what the Euro would have been. |
Just make sure the Euro bumpers and lights are in good condition. Not the same bumper lights as US version and €€€'s expensive from Europe.
If it has original Euro headlights (unlikely) they will not shine the sides of the road like the US headlights do. Not a bad thing but just be aware that the you will not clearly see the unlit traffic signs here. In Europe they have lit traffic signs. If the engine gives good compression and leak down numbers the 10.6 compression on the Euro's is a plus. Premium gas though might be a minus. Some Euros came without a CAT from the factory, that might be an issue with emmisions depending on which state you are in. BTW it's not an 85.5 it's an 85. The 85.5 thing is a US model issue. All 85 models in Europe had the facelift dash or as they call them the "Oval Dash". |
Originally Posted by MAGK944
(Post 10128881)
If it has original Euro headlights (unlikely) they will not shine the sides of the road like the US headlights do. Not a bad thing but just be aware that the you will not clearly see the unlit traffic signs here. In Europe they have lit traffic signs. If the engine gives good compression and leak down numbers the 10.6 compression on the Euro's is a plus. Premium gas though might be a minus. Some Euros came without a CAT from the factory, that might be an issue with emmisions depending on which state you are in. BTW it's not an 85.5 it's an 85. The 85.5 thing is a US model issue. All 85 models in Europe had the facelift dash or as they call them the "Oval Dash". Euro cars don't have the side lights, not sure what you mean by it wont shine on signs? |
Originally Posted by Paulyy
(Post 10129072)
The euro front bumper lights are different to US spec ones. ALL euro spec lights have front fog lights.
Euro cars don't have the side lights, not sure what you mean by it wont shine on signs? As for the Euro headlights, they shine all the light to the front whereas US DOT headlights scatter some of the light to the side to illuminate traffic signs. Hope that explains it. |
This post explains it better than I did. http://jeepsunlimited.com/forums//sh...78&postcount=1
But...a lot of people here convert to euro e-code lights for the better road pattern. The are sold for off-road use only but that doesn't seem to deter anyone, including me ;) They do give better straight ahead vision and as long as your state doesn't check for DOT makings then it really doesn't matter. |
(Post 10129110)
What I meant to say was the euro bumper lights are unique to the euro. They are "driving" lights rather than fog lights and euros had a fog light option for the front spoiler that fit where the US front lights are. That front spoiler/valance came with or without light cut-outs in Europe.
(Post 10129130)
The lights in the bumper are the high beams. Mine has no fogs, valance has no opening for them. Car has the switch, must have been changed post front impact in its past life in Austria. No side lights either.
I have the no-cat exhaust, but I am using the US spec exhaust with the 02 sensor. |
Originally Posted by art
(Post 10135475)
The lights in the bumper are the high beams....
I don't think there are sidelights on any Euro car, they had smaller side repeaters for the turn signals only. |
