968 trans in 951S
968 trans in 951S
hi I just recently installed a 968 trans in my 89 944 turbo S the trans is a direct bolt in, using a 968 trans mount. but now I ran into a problem my speedometer doesn't work. because the new trans doesn't have the pick up signal point built in. I heard the 968 picks up the signal from the ABS. any ideas how to get my speedometere back to work.
thank you
phil
thank you
phil
The 968 and 951 ABS are exactly the same. The trick is picking up the wire from the brain that sends the signal to the (different) instrument panel the 968 uses. Like Tom says, check the archives for how Mike did it.
Originally posted by SATX 944T:
<STRONG>Phillip,
Apart from getting 6 speeds, what are the other benefits that you expect to get from the 968 gearbox ?
Wayne</STRONG>
<STRONG>Phillip,
Wayne</STRONG>
Another benefit is the 968 gearbox uses the same differential as the G50 and 993 transmissions. LSDs for these gearboxes are readily available from the factory, Quaife, or Guard Transmission. It's also possible to swap the differential without pulling the trans since it can be removed without moving the pinion out of the way like you have to do with the 944 box.
Cheers,
