Radiator Pressurizing Tool/air removal tool???? Or can I fab. one???
Geaux Tigers!
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Just a thought. Is there a Radiator pressurizing tool, say like a cap, that will help get any air pockets out of your car?This would be great as the "milking" method and the "mouth to mouth" are such a pain. Have y'all seen such a tool?
Or, I'm thinking I may be able to fab one by buying a new cap. Drilling a small hole in it with my Dremel tool that will fit a Basketball pump needle in the hole. Then seal the hole up (needel connected, ofcourse) with silicone. This could be used in conjunction with a hand pump to help bleed the radiator,,,,,,,,,,,,couldn't it? Seems like it's doable. Anyone with a better idea? Or, comments????????
As tabor: they exist.
Mine is a cap (old) with a "tubless tire valve"(dont know the correct name, Schraeder valve?).
I used the complete assembly, incl the rubber part that normally goes in the rim.
I use the car's electrical pump to pressurise. For pressure checking, the valve is taken out so the indicator responds.
Does not make bleeding of the coolant circuit faster though, just a bit less difficult. Milking is still required....
