NA Exterior Completed!!!
Has anyone else experiences the spring plate being fused together?
Today I got
My Custom Title
My Custom Title
The only way I got mine to break free was by soaking it in pb blaster and hitting it with impact wrench every day for a week until I gave up. THEN I solved my problem by lifting the car, inserting breaker bar touching ground, and lowering the car's weight onto the breaker bar. That 1000+ ft lbs did the trick
Today I got
My Custom Title
My Custom Title
If it comes loose ok, I don't know why you'd replace. Don't even know where you could find a replacement
I like it, I've always liked the side stripes/ scripts on most P-cars. I'm planning on doing black carrera side stripe/ script on my 996. If it don't like the way it turns out, then it's easily removed.
I agree with what others have said, the stripe continuing past the rear wheel well is a little much, I think it'd look cleaner without that, and without the silver on the nose. But all in all, tastefully done...
Generally, I am more of a purist with a slight leaning towards only 'tasetful' mods. I have to say your's is very nicely done.
As someone else mentioned, the short decal on the front wing/fender looks a little out of place visually. It doesn't really anchor to any curve, contour or piece. It appears the drip rail is painted silver, that to me breaks the overall profile line in a negative way. 16" Fuchs and a lowered stance may very well give the look that last 1% and really make it stunning.
Today I got
My Custom Title
My Custom Title
Today I got
My Custom Title
My Custom Title
You lower it to the absolute lowest setting in the eccentric, it'll get the car no more than 1" lower.
Here's the diagram I used to help figure out what I was doing:
