FS-87 951 front hubs, bearings, spindles, rotors calipers, and pads
Complete set up off of a 87 951. Asking 300.00 plus shipping, but open to offers.
Complete hubs, bearings, spindles, rotors, calipers, and pads
I'll jump in here cos I've done this on an 86.
Everything will bolt up fine and retain the early offset. The only issue is you need to fit camber plates for adjustment. You need them because the later spindles sit at a different angle on the struts, 4 degrees iirc. This limits your camber adjustment so you need the plates for full range of adjustment.
Why do it: the 87+ hubs/spindles are much improved, larger bearings and stronger than earlier models. GL
