Another offset question.
Ok my head is spinning . Looking at these wheels and their offsets. Which fit an 86, 951 best and what spacers are needed????? I know offsets have been heavily discussed but it still messes with my head. HELP!
Euromeister
17x7 23.3 offset
17x9 15 offset
Rota
17x7.5 35offset
17x9 16 offset
Euromeister
17x7 23.3 offset
17x9 15 offset
Rota
17x7.5 35offset
17x9 16 offset
Take your stock wheel offset, and subtract the new wheel offset. If the number is positive, you need a spacer that size. If the number is negative, it won't work.
Both will fit, both will reguire spacers to clear the front calipers.
Euromeisters will be 5mm further out towards the fenders in front, and 1mm in the rear.
Correct me if I'm wrong, but aren't both of those wheel sets early 911 offset ? The rear outside lip would move approximately 33 mm outward.
Edit: Oops! Did the math wrong , would move the outer lip out approximately 21 mm.
Today I got
My Custom Title
My Custom Title
Euromeister
17x7 23.3 offset
17x9 15 offset
Rota
17x7.5 35offset
17x9 16 offset
Euromeister
17x7 23.3 offset
17x9 15 offset
Rota
17x7.5 35offset
17x9 16 offset
The Rota fronts will probably need small spacers (1cm or so) because the offset for that shouldn't be much higher than 23mm.
The euromeisters would be perfect on your car without spacers, but as stated above the 86 951s will need a small spacer to have the wheels clear the 951 calipers. The spoke design on the euromeister and rota wheels is very similar to that on the 911 fuchs, and because of this will rub the 951 caliper without a spacer.
